replaced front brake switch now blinkers
Old Feb 27, 2010 | 12:36 AM
MoonCricket's Avatar
MoonCricket
Default replaced front brake switch now blinkers
Hello Gang, here is my situation. i replaced my faulty front brake switch. all went well with re install. however when i reconnected the neg. battery wire to check, I noticed the fuel pump did not work nor did any of the turn signals. checked all the fuses and found the ignition fuse was blown. opened back up the switch housing and found that i pinched one of the stop run wires. applied some liquid electrical tape and closed the switch housing back up. with all that said my turn signals dont work, right or left. can it be from the ignition fuse or something else? btw my front brake light works fine......any ideas
Old Feb 27, 2010 | 09:14 AM
MoonCricket
fish-r-ride
Apr 25, 2021 12:42 PM
Henry89
Aug 23, 2014 12:39 AM
gambler85gw
Jul 9, 2014 02:21 PM
MoonCricket
Feb 28, 2010 05:49 PM
trapperdog
Jan 15, 2008 05:52 PM
