Hyperflash on Dash - LED Install
Old Sep 29, 2015 | 09:39 PM
ScottMcN1's Avatar
ScottMcN1
Default Hyperflash on Dash - LED Install
I recently removed all turn signals and went with Rolland Sands Designs and I am running into a minor issue. I cut the wires at the hand controls, heat tubed, and rolled back into the controllers. For the new signals I installed them on the forks me have them going into the auxiliary plug ( Harley makes for turn signal relocation / lighted mirrors, etc).
All works perfect for flashing except in the dash I have a hyper flashing signal only for left and right, not 4 way.
For those of you with experience in can systems, should I be wiring my signals into 'can low' and 'can high' that run up to the hand grips? I am wondering if it can't tell the lights aren't there.
Thoughts anybody?
Old Oct 1, 2015 | 03:34 AM
TriDan's Avatar
TriDan
I just had this. External turn signals flash normally and the flasher on the dash hyperflashed.
Go to the dealer and get a load balancer. It took me about 3 minutes to install, take seat off, disconnect flasher plug, plug this in, put seat back on, right signal, left signal, right signal, done.
No more hyperflash
Old Oct 1, 2015 | 03:41 AM
ScottMcN1's Avatar
ScottMcN1
Does your bike have a can bus system?
Old Oct 1, 2015 | 06:38 AM
TriDan's Avatar
TriDan
2012 Fatboy Lo. Yup.
Old Oct 15, 2015 | 02:32 AM
TheBruinsFanGrumps's Avatar
TheBruinsFanGrumps
6th Gear
If you have the can bus system, you should be able to run your bike with the hazard lights on for 5 minutes to reset / resync the can bus system with your new lights voltage readings. This removed the hyper flashing on my SGS.
Old Aug 26, 2018 | 10:50 AM
johnnythrottle's Avatar
johnnythrottle
Reset dashboard signal indicators: (canbus equipped models only)
-turn key to start position.
-run 4-ways for 20-30 seconds
-leaving 4-ways on, turn key to off position then back to run.
Done deal.
choughto
Apr 9, 2017 03:08 PM
Jparra94
Feb 15, 2016 05:50 PM
Winston74
Electrical/Lighting/Alarm
Feb 17, 2015 06:24 PM
Needle750
May 1, 2013 09:32 PM
Tookeman
Jul 7, 2008 03:44 PM
