NO BRAKE LIGHTS. Error code b2161
Old Oct 25, 2015 | 03:09 PM
Munster73's Avatar
Munster73
Stage IV
Default NO BRAKE LIGHTS. Error code b2161
I have a 2016 iron 883 the dealer installed an alarm system and the red light stays on the speedo when I'm riding. I asked them about it they said that's normal. I noticed the other day I have no brake lights. The running lights are on, but the brake lights do not activate. I'm getting a error code b2161 and the pn is 69994-128. Any advice?
Old Oct 30, 2015 | 12:07 PM
enodrano's Avatar
enodrano
The red key light is used to indicate two different situations:
1. Security System Status
2. Diagnostic Trouble Code (DTC) Status
Your 2016 bike has a CAN-Bus electrical system. In short a CAN-Bus system can communicate with electrical components. A common mistake is installing electrical accessories that are not CAN-Bus compatible. For example: at an auto parts store you will see LED stop/turn/run (1157) bulbs sold in two different flavors, CAN-Bus compatible and not compatible.
If you have not made any changes to the stock electrical system, since you have a bike that should still be under warrenty, I would bring it to a dealer.
Good Luck!
Old Feb 14, 2016 | 08:08 AM
mikehdstreetglide's Avatar
mikehdstreetglide
Stage IV
Default same problem
I have a 2016 FLHX street glide. I also had a security system installed by hd dealer. I am having the exact same problem as you. Same codes also. Let me know the fix for it. If I get mine resolved I'll post it here.
Old Feb 14, 2016 | 08:11 AM
RANGER73's Avatar
RANGER73
The red key is telling you you have a bulb out in this case.
Do you not get brake light with both front lever and brake pedal?
Old Feb 14, 2016 | 08:25 AM
mikehdstreetglide
Stage IV
No brake lights with front lever or rear pedal. The HD shop says the systemw as set up wrong. The system is not recognizingt he brake lights. I am taking it back to dealer this week.
Old Feb 14, 2016 | 10:53 AM
14GuineaPig's Avatar
14GuineaPig
Take it back to the dealer
Old Feb 14, 2016 | 11:13 AM
mikehdstreetglide
Stage IV
Thanks for posting that. That is basically whatt he service technician had said.
Old Feb 14, 2016 | 11:59 AM
14GuineaPig
I figured I'd post it but I'm not sure if his model has no center stop lamp.
Old Feb 14, 2016 | 12:00 PM
Munster73's Avatar
Munster73
Stage IV
Default Problem solved.
Thanks for the advice. I took the bike back to the dealer and they reprogramed it. No problems since.
Originally Posted by enodrano
The red
Good Luck!
Old Feb 14, 2016 | 12:02 PM
Munster73's Avatar
Munster73
Stage IV
