Headlight Question
Old Nov 7, 2015 | 08:19 PM
daddyflea's Avatar
daddyflea
Default Headlight Question
I have a 2014 Road King with the CVO two bulb Headlight system. Is it possible to program the Computer to allow the Low Beam to stay on when the High Beam is activated?
I am replacing the bulbs with LED so the Heat should be less. Question is would this be too much Heat for the Light Assembly to Handle.
Old Nov 8, 2015 | 09:20 AM
grbrown's Avatar
grbrown
It shouldn't be too much heat with normal halogen bulbs to run them both together and certainly hot too much with LED ones, as they use less electrical power and give off less heat. Hopefully someone can answer your programming query.
Old Nov 9, 2015 | 11:49 AM
Schoolam's Avatar
Schoolam
I was under the impression that the low beam stays on with the high beam on those models? Am I wrong? Also, the LED bulbs give off considerably less heat than the halogens and with both bulbs on you will not have an issue with the heat causing damage
Old Nov 9, 2015 | 12:22 PM
daddyflea's Avatar
daddyflea
Harley says no on 2014 both bulbs can not be programmed on at the same time.
GOGOBECK
EVO
17
May 16, 2018 08:05 PM
Sparkules
Electrical/Lighting/Alarm
Apr 4, 2018 10:14 AM
mibeaulieu
Touring Parts
Jun 20, 2016 08:03 AM
98hotrodfatboy
EVO
24
Feb 3, 2016 11:40 AM
sonar_chris
Nov 18, 2015 12:03 AM
