B2137 error code (Daymaker) only when Wet
Old Dec 26, 2015 | 06:09 PM
TruckerXbones's Avatar
TruckerXbones
Default B2137 error code (Daymaker) only when Wet
Installed a 5.75 Daymaker on my 2011 softail. When the bike is wet, either riding through rain or just after washing, I get the b2137 error code when using my high beam. I know the code is for "low beam output shortage high" and others have posted on this forum the same code after installing LED lights. Mine only does it when wet, I tried simulating it by spraying water on the headlight and the headlight plug and it doesn't do it. It's really not a big deal, does not do it when it dries out. I just wanna make sure something isn't exposed and getting wet that shouldn't.
Old Jun 17, 2017 | 09:32 PM
Ranger702's Avatar
Ranger702
I just washed my 2017 48 with the leds and same codes. Going to let dry overnight and see wrf?
Old Jun 19, 2017 | 08:55 AM
Zanthamos's Avatar
Zanthamos
Sound like you have a slightly loose or no dielectric grease on one of the connectors under the fuel tank.
Old Jun 19, 2017 | 09:00 AM
Ranger702's Avatar
Ranger702
What grease and where do you recommend it be placed? After the bike dried overnight no error codes. So it's got to be the grease.
Old Jun 19, 2017 | 11:01 AM
Zanthamos's Avatar
Zanthamos
At each electrical connector there should be some dielectric grease to prevent the moisture from getting into the connectors. Petroleum Jelly works well as a dielectric grease in a pinch.
Old Jun 19, 2017 | 04:58 PM
TruckerXbones
Been a year and half or so since I put the LED in. The problem seems to have gone away, run through a ton of rain and wash the bike a lot. System may have adapted. Just keep clearing the codes and it might fix itself. Got codes from installing rear led turn signals but only if you use them with the engine off. Think that fixed itself too. Wish all the other parts on this bike were "self-healing"...lol
Old Jun 19, 2017 | 05:10 PM
Ranger702's Avatar
Ranger702
Yea bikes are all characters
RedBeard330
Electrical/Lighting/Alarm
Mar 29, 2023 09:31 AM
Bluesrider.df
Jul 20, 2018 01:54 AM
BLKDLX
Sep 21, 2017 10:32 PM
Reno007
Apr 19, 2017 10:47 AM
Jcp
Jun 12, 2015 12:14 PM
