Erratic charging
Old Jan 4, 2016 | 05:57 PM
Eric Hays's Avatar
Eric Hays
Stage I
Default Erratic charging
I have a 02 FLHT that while at idle maintains a constant 14v charge. When rpm's get above 2200 the bike voltmeter begins moving between 11-14.5v. I've double checked the VR connections, batter terminals, fuses, and relays but am totally stumped.
Old Jan 5, 2016 | 07:31 AM
nhrider1's Avatar
nhrider1
First thing to do is verify the voltage reading with an external volt meter. You want to make sure the gage is accurate.
If it is accurate you want to check the stator and voltage regulator. There are stickys in this section that will walk you through the procedure.
Old Jan 5, 2016 | 09:13 AM
grbrown's Avatar
grbrown
Hi from the UK and welcome to HDF. As nhrider1 says, use a multimeter to confirm what your bike's voltmeter is saying. Whenever doing electrical work use a multimeter, which will be much more dependable than the one on your bike. After all, your bike's voltmeter is a part of the electrics you are checking - there is no certainty it will tell you the truth!
Dave Bell
Aug 10, 2016 10:20 AM
oil leak
Ironhead
Oct 25, 2012 08:47 PM
Lingleha
Jul 8, 2012 05:34 PM
glenns
Jun 26, 2009 02:19 PM
timberwolfz28
EVO
Jun 25, 2009 09:05 PM
