hi any help would be appreciated
when my turn signals flash when the security is activated
its makes my radio flash on for a split secound then off until the lights stop flashing
could this be a ground problem?
thanks randy
Not quite sure on the wiring schematic of an 11, but pull the fuse for the radio (Radio Fuse) and see if it does it with the fuse out, sounds like something is back feeding the radio when the security engages.
I took the fairing back off disconnected all the connector on the ultra overlay harness
Still does it
Then unplug the switch housing still did it
Unplug the radio connecter radio did not come on then but the speaker light still flash
I took all the grounds off and clean them
Could it be the tssm
Or the ecm
Thanks randy
Again I am as far from experienced at this as one could be but, according to my schematics (2015 Ultra) the radio is fed directly through a fused circuit from the battery so I couldn't see how the TSSM or ECM or BCM could have play on this issue.
