Hoping to get some guidance here. So my tail light is functioning, but my brake light does not illuminate when either the brake lever or pedal are used. First I checked the bulb and its fine, even switched the wires to make sure both filaments worked. Next I changed all the fuses and those are all good. I followed the brake light wire up to the wiring harness and cannot find anything there or along the way. Any help at this point would be greatly appreciated. Thanks. Nait.
Reconnect the wires to the rear brake light switch.
Trace the red/yellow wire back to the connector toward the rear, it will have about 8 wires.
Unplug that connector and check for voltage at the terminal where the red/yellow wire is while activating the brakes.
