factory ECM or alarms a Parasitic drain?
Old Aug 17, 2016 | 10:23 PM
americanworkmule's Avatar
americanworkmule
Default factory ECM or alarms a Parasitic drain?
Are the factory ECM or alarms a Parasitic drain?
I'm wanting to get a smaller battery for my 2003 Softail so I can install a solo seat and Lucky Sucker fender.
Anyway, I've seen where others have recommended the Antigravity YTX12-16 16-Cell Lithium Ion Motorcycle Battery.
but the website states:
Can hold a charge up to a year provided there are no ”Parasitic Drains” (accessories that draw power when the bike is off…such as alarms, ECUs, iPods, GPS, heated grips etc…)
http://antigravitybatteries.com/ytx12-16/
So I didn't know whether to go this route or not.
Thanks
Old Aug 18, 2016 | 11:01 PM
Vernal's Avatar
Vernal
Thanks
There is a small drain for ECM, If you want to know how much of a drain you have pull the the main fuse and set your meter to read milli amps and measure across the fuse socket.
simple softail
Dec 7, 2016 03:52 PM
Micah461
May 31, 2015 08:18 PM
Falcon195
Jul 28, 2013 07:36 PM
Austin Dave
May 3, 2012 09:41 PM
dert
Feb 22, 2008 07:41 AM
