Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Last year I installed a Gorilla alarm system. I've had a suspicion that it has quite a large parasitic drain on the battery since. I bought a new DMM the other day and tested the load. The alarm is putting a 9.4mA drain on the battery. That is about 3x more than I expected. That is quite high, isn't it?
New battery this year. When charged after a ride it will read 12.76v and within 2-3 days it will read 12.1v. I don't know enough about this subject so I thought I'd ask and hope someone who does could help. Thanks.
Sounds life you might have a defective battery as long as charging system is healthy. 9.4ma is very slight and should take weeks to drain a good battery.
Miss this part?
*New battery this year. When charged after a ride it will read 12.76v and within 2-3 days it will read 12.1v.*
