LED issues
Old Oct 24, 2016 | 11:06 AM
livinlow's Avatar
livinlow
Stage I
Default LED issues
I have an 07 Low Rider that I bought used. It only had front turn signals on it. I bought rear signals and LED's for all four lights along with a Custom Dynamics load equalizer. Installed all per directions and lights were still Hyper-flashing. Thinking maybe the load equalizer was bad I changed it out. Still got Hyper-flashing. I put in regular bulbs and no Hyper-flashing. Then put LED's in rear and no Hyper-flashing. Put front LED's back in and it returned to Hyper-flashing. Any ideas or suggestions?
Old Oct 24, 2016 | 12:38 PM
fordhd2005's Avatar
fordhd2005
Assuming you load equalizer is connected/wired correctly, you may need to synchronize it. Turn the key on and perform a turn signal synchronization. With the key in the run position and the motor off, press the right turn signal button and allow the turn signal to flash 2 times, after the second flash press the left turn signal button and allow the turn signal to flash 2 times, after the second flash press the right turn signal and allow it to flash at east 10 times. Turn key off.
Winston74
Electrical/Lighting/Alarm
Feb 17, 2015 06:24 PM
CJinNH
Aug 11, 2014 09:26 AM
chiefaponte
Apr 7, 2013 09:37 AM
fiscomi
Jul 30, 2010 09:03 AM
z28kilr
Apr 14, 2010 11:53 AM
