2001 Dyna headlight swap woes
Old Feb 5, 2017 | 07:21 PM
NavyHD's Avatar
NavyHD
4th Gear
Default 2001 Dyna headlight swap woes
Hey, I'm trying to swap my headlight out and I am now having issues where I don't have power to the headlight or the taillight. I'm looking at the wiring schematic and the only thing that they really haven't come and from what I can see is the ground. I have checked the ground wires and they are solid. I did not have this issue before I started. I've checked every connection I've dropped a meter on the terminals for the plug for the headlight the bike will start and run no issues the turn signals work only when you want the signal to blank. It does not illuminate with the switch on in the ignition position.
Old Feb 6, 2017 | 11:19 AM
Vernal's Avatar
Vernal
Did you check the Lights fuse?
Old Feb 6, 2017 | 11:20 AM
NavyHD's Avatar
NavyHD
4th Gear
I'll be checking out today, thank you very much for helping
Old Feb 7, 2017 | 04:57 AM
NavyHD's Avatar
NavyHD
4th Gear
It was indeed the fuse. I had the battery disconnected when I was doing the swap too.
Thanks for the help
Old Apr 22, 2017 | 04:11 AM
LaRider's Avatar
LaRider
hey navyhd, do you have the run turn brake mod,,i have a 01 as well. and Harley don't make one for the 01,
was wondering what you used if you did
thanks
NavyHD
Electrical/Lighting/Alarm
Feb 5, 2017 07:20 PM
NavyHD
Feb 5, 2017 06:44 PM
seandrew
Dec 16, 2013 09:00 PM
lloydrtr
Nov 4, 2011 08:10 PM
blueglide88
EVO
Aug 14, 2008 02:55 AM
