Blinker issue.
Old Feb 25, 2017 | 10:43 AM
Vegasvato's Avatar
Vegasvato
Stage II
Default Blinker issue.
Just bought a '97 Heritage Softail Classic & can't turn on the right blinker from switch but when I hit the brake pedal the brake light comes on & the right turn signal starts blinking & won't turn off unless I hit brake pedal again.
Suggestions?
Old Feb 25, 2017 | 11:46 AM
enodrano's Avatar
enodrano
The easiest and cheapest thing to try first is replacing the bulb. You most likely have a 1157 bulb with two filaments. One filament is for the blinker and one is for the brake light. When the brake and blinker are on at the same time I think the Brake filament blinks. The blinker only filament is probably blown.
Old Feb 25, 2017 | 10:47 PM
Vegasvato's Avatar
Vegasvato
Stage II
Thank you enodrano , I will give that a try tomorrow.
Old Feb 26, 2017 | 01:54 PM
14GuineaPig's Avatar
14GuineaPig
Unless you have a converter to convert your rear turn signals to also work as brake lights, then your turn signal is separate from your brake light. If you do have a converter, try disconnecting that first to see if that is defective.
If that does not fix your problem, it could be a wiring problem. Have the handlebars or hand controls been changed recently?
This thread might also interest you:
https://www.hdforums.com/forum/evo-c...l-problem.html
PhilHD
Electrical/Lighting/Alarm
Jun 3, 2015 12:44 PM
Mark (Rooster)
May 14, 2015 12:17 PM
Stubborn-Dave
Mar 28, 2014 11:56 AM
vinzilla
Sep 3, 2013 09:48 PM
dawg
Sep 5, 2006 11:19 AM
