Lighted Hand Control Switch Part# 71500248 defect
During install of this part last weekend I noticed that when torquing to factory spec it would cause some binding on switches on top side both clutch and brake side. So I hand tightened until the switch operation was uninterrupted and torqued the master cylinder brackets. Everything worked fine but there was a tiny gap on the switch covers about half a mm.
Well today my OCD kicked in and I took throttle side apart to investigate further. After some searching online find no issues and I was beginning to believe it was a OD on the new bars. I took the switch out and tried to bolt up the covers around it off the bike and found it was still not working. So I began inspecting it and found there was a tiny manufacturer defect that was preventing them from seating properly. I pulled out the old switch and compared it as well and it was obvious someone did not have the machine at the plant setup properly as a little groove that the cover rests in was not cut deep enough.
Hard to see but the little groove at the end of my pick there was not deep enough and the housing has a guide that rests in there.
2 minutes each side with an exactly knife and it fits together perfect.
It may have been a bad batch. So, if you happen to be riding around with a tiny gap or sticky top switches you may have the same issue. It was easy to fix but a little hard to find. Outside of that it was a super easy install and definitely not worth the dealer cost of an hour.
