I need help
Old Mar 30, 2017 | 01:41 PM
Paul Walbroehl's Avatar
Paul Walbroehl
Stage IV
Default I need help
my turn signals in the front work but my left running light does not. I'm new to motorcycles. I have a 2012 harley 883 super low. I need some helpful advice please
Old Mar 30, 2017 | 04:12 PM
13RoadKing's Avatar
13RoadKing
Get electrical diagram and multi tester.
Old Mar 30, 2017 | 04:21 PM
davidwruth's Avatar
davidwruth
+1 on manual and meter. Dumb question did you check the bulb? Switch bulbs and see if it changes
Old Mar 30, 2017 | 10:44 PM
Paul Walbroehl
Stage IV
I did try that because the turn signal works. if the turn signal works should I still try switching them? Also where can i get the diagram? thank you for helping out!
Paul Walbroehl
Stage IV
I'm sorry didn't not "did"
Old Mar 30, 2017 | 10:59 PM
Vernal's Avatar
Vernal
Hi Paul and welcome to the forum. Being new to motorcycles the 2012 883 will be a fun ride. I'm not real familiar with the Sportsters but I can give you links to the electrical Schematics : if you look at the Main Harness 2012 Sportster drawing you'll see a fuse for lighting. A blue wire comes off the fuse and if you follow it you'll see it goes to a connector at he top of the drawing, connector 31A and it tells you to see Lighting 2 of 2. scroll down to that drawing. On Lighting 2 of 2 in the upper left you find the front lighting, connector 31B and 2 blue wires to the running lamps.
Did you take a look at the bulb it is a dual element, one for turn and one for running light. Maybe you just need a new bulb? If you have a volt meter perhaps you could check the blue wire to see if it has voltage at the connector.
https://serviceinfo.harley-davidson....d-d44bf7213f3d
This is a great site and where the schematics came from.
https://serviceinfo.harley-davidson....uring&id=56344
Good luck and let us know what you find.
Bill
Old Apr 1, 2017 | 12:03 AM
Paul Walbroehl
Stage IV
hey guys thank y'all for helping out! bill once I read the "duel element " about the bulb it made sense to what the problem was. 7 dollar fix......it was the darn bulb!! sort of feel like an idiot. i was more upset cause I just got the bike so it sort of irritated me, including tires that dry rotted within the month.....anyways thanks guys made my day to see all the lights working!!
Old Apr 1, 2017 | 10:18 PM
Vernal's Avatar
Vernal
Glad you got it working, now enjoy the new ride
SouthernGent
Electrical/Lighting/Alarm
Dec 2, 2012 10:30 PM
snakeyes
Apr 29, 2011 12:17 AM
jeffwest5599
Jul 20, 2007 10:13 AM
cleanandsimple00
Jul 17, 2007 02:17 AM
tik1803
Jun 9, 2007 02:31 AM
