Turn Signal Issue
Old Jul 18, 2007 | 09:47 PM
jeffwest5599's Avatar
jeffwest5599
Default Turn Signal Issue
I just purchased a 1996 Harley Softail Bad Boy. I am having an issue with the turn signals. When I push in the turn signal button, the light comes on in the fornt and the back on each side but it does not blink. All of the bulbs are OK and it shuts off after you turn. Could this be a relay and if so, where are they.I checked everything under the seat and did not find anything. Any help is appreciated.
Old Jul 18, 2007 | 10:02 PM
biz44's Avatar
biz44
Default RE: Turn Signal Issue
If the lights still work, but just dont blink, I would think its your flasher relay thats bad, although I will be of no help to you in finding its location.
Old Jul 19, 2007 | 06:33 AM
jeffwest5599
The hazards work when you push them both in but they do not blink when you use the blinker. It is strange.
Old Jul 19, 2007 | 07:11 AM
harleypup's Avatar
harleypup
Are they the standard indicators or have smaller aftermarket ones been fitted? Sometimes when they are fitted with smaller indicators you need to have a regulator fitted to make sure the correct amps are getting to the bulbs, otherwise they will go on but not blink.
Old Jul 19, 2007 | 10:51 AM
michaelbarry's Avatar
michaelbarry
Yep..sometimes when you play around with your lights, you need to have a load equalizer..
Old Jul 20, 2007 | 10:13 AM
Milwaukee Steal's Avatar
Milwaukee Steal
ok, here's a definite "try this" for you. I know you said the old bulbis ok. Have you put in a new bulb, tho.?? I had exactly the same thing on my 05 heritage. The bulb in the back right hand side would not blink. I looked at the bulb and it looked fine. But as they say, "the proof is in the pudding"........I put in a new bulb and it worked fine. My old bulb looked fine but did not function fine. Try putting in another bulb. Won't take anything but a little time.......Hope this helps.
Patrick1979
Electrical/Lighting/Alarm
Jul 9, 2015 09:19 PM
snakeyes
Apr 29, 2011 12:17 AM
z28kilr
Apr 16, 2010 11:58 AM
cleanandsimple00
Jul 17, 2007 02:17 AM
tik1803
Jun 9, 2007 02:31 AM
