turns with running?
Old Jul 9, 2017 | 10:47 AM
rydahog's Avatar
rydahog
Default turns with running?
i have 2001 dwg, my Front turns OEM are 2 wire..i assume turn/grnd.....what the best way to make them turn/running light? thanks..
Old Jul 12, 2017 | 02:21 PM
Zanthamos's Avatar
Zanthamos
In the pic is that both front and rear lights or is that a stock photo? If that is both front and rear lights then someone swapped the front and rear lights previously as the rear are on both DOM and INT models single filiment bulbs, but the front DOM models are dual filiment bulbs but the INT models are single filiment bulbs. The O/W wire will go to the blue on the front lights for marker lights. If you want the rear to be the same then you'll have to get dual filiment sockets for them and run a wire to the O/W.
Gla4g
Dec 19, 2017 10:34 AM
Jack D
Mar 5, 2013 12:54 AM
machm1969
Jan 15, 2013 06:32 PM
postalnut
Sep 9, 2012 04:37 PM
HDF Tech
Electrical/Lighting/Alarm
Nov 16, 2011 06:56 AM
