Taillights/Running lights problem
Old Sep 8, 2012 | 06:19 PM
postalnut's Avatar
postalnut
3rd Gear
Default Taillights/Running lights problem
Had my 2012 Sporster superlow 883 for a couple month. And i just noticed my rear running lights are not lit, but the front ones are. Directionals work front and back.Headlights and Brake/taillight work. Have i just assumed the back ones were lit because the front ones were lit? I could have sworn the were working before? Any words of wisdom?
Old Sep 8, 2012 | 06:34 PM
davidwruth's Avatar
davidwruth
Single filament bulbs in rear. Only turn signals.
Old Sep 8, 2012 | 06:55 PM
postalnut's Avatar
postalnut
3rd Gear
That seems odd, but that helps a lot. Thank You
Old Sep 8, 2012 | 07:15 PM
Jackie Paper's Avatar
Jackie Paper
Harley and aftermarket probably has a simple black box (nothing but diodes in it) with two plugs to plug into your wire harness. You change out your rear lens to red if they aren't already. Then your rear signal lights will become brake lights also.
Old Sep 8, 2012 | 07:53 PM
postalnut's Avatar
postalnut
3rd Gear
Great for safety. I will look into that. You guys are the best
Old Sep 8, 2012 | 08:02 PM
davidwruth's Avatar
davidwruth
Custom dinamics has a great triple play. Have it on my bike love it
Old Sep 9, 2012 | 12:00 PM
postalnut's Avatar
postalnut
3rd Gear
I have the single filament bullet turn signals. Can i still get the triple play or need to replace the bullets to LED's
Old Sep 9, 2012 | 12:14 PM
davidwruth's Avatar
davidwruth
They come with led boards that fit in the bullet lights took about 15 mins. To install everything
Old Sep 9, 2012 | 04:37 PM
postalnut's Avatar
postalnut
3rd Gear
Spectacular. Sold. Thanks David
Gla4g
Dec 19, 2017 10:34 AM
86glider
EVO
16
Oct 19, 2017 02:40 PM
Dagda889
Feb 14, 2017 12:14 PM
Ted Tyler
Aug 14, 2012 10:54 PM
Stevieskull
Apr 4, 2012 02:12 PM
