Another hyper flash issue
Old Sep 23, 2017 | 01:53 AM
Kerosene's Avatar
Kerosene
Default Another hyper flash issue
I recently relocated my front and rear turn signals with smaller bullet 12v LED lights. The front turn signals are only a two wire design so I lost my running lights. The running light wire in the meantime is just electrical taped off. I'm planning on installing resistors to correct the load on the turn signals.
But my question is with the load on the running lights which is none. Is it just a matter of running a resistor in line with the hot running light? One wire of the resistor going to ground and the other to the running light wire?
Old Sep 23, 2017 | 11:27 AM
bustert's Avatar
bustert
remember, resistor do just as they say resist and that creates heat so be careful of where you install.
it might be a little while but i will post a jpeg of what you need and where to place it. no need for individual loads, this takes care of them all. i will have to retrieve it from photobucket and upload to imgur(thanks pb).
all you need to do is solder the input wire ends to the board so that they are stiff, you can insert them into the connector on the turns module.
Old Sep 24, 2017 | 07:31 AM
Kerosene's Avatar
Kerosene
That diagram is super helpful, thank you! This only makes the bike think there's running lights installed, correct?
​​​​​​​would this setup be sorta the same thing as the Custom Dynamics Load Equalizer?
Old Sep 24, 2017 | 04:34 PM
bustert's Avatar
bustert
running lights do not need resistors unless of course the led does not have internal dropping resistors. the turns need the load, the new units do not as i understand it. the reason you put the input from the board into the connector hole that have the wires exiting out to the lamps on the module no need to feed the running.
Old Sep 24, 2017 | 11:16 PM
Kerosene's Avatar
Kerosene
​​​​​​​Great, thank you, I have some direction to get the signals to flash normally.
Old Sep 25, 2017 | 07:24 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Deleted post, already answered by bustert.
Old Oct 3, 2017 | 01:38 AM
Kerosene's Avatar
Kerosene
Installed the Custom Dynamics load equalizer and that corrected the issue. The red dash light also is no longer on. What an easy product to install. Just wanted to share what worked for me.
BMyers
Jun 10, 2014 09:09 PM
BFDHD14
Oct 28, 2013 05:19 PM
jfarrar30
Feb 7, 2012 08:54 PM
rhinodog
Feb 3, 2012 09:36 AM
Voodoo
Nov 16, 2006 09:29 PM
