New LED headlight install help. Please.
Old Oct 7, 2017 | 01:23 PM
wideglideCVO's Avatar
wideglideCVO
Default New LED headlight install help. Please.
I just installed a new LED headlight bulb 5/3/4" ebay $62.00 bulb three prong for a 2002 wide glide. Problem is Hi and low beam work for running light now and when I put the hi beam switch on both Hi and low beam go off? I checked with a volt meter which wire was ground and which wire was for high beam, any help would be appreciated. Thanks.
Old Oct 8, 2017 | 11:12 AM
larsfum's Avatar
larsfum
Double check your connections, but that light should be plug and play. If the connections are good then the light is bad.
Old Oct 9, 2017 | 05:53 AM
wideglideCVO
The problem was there was no female plug, it had been removed and just the three wires were attached to the stock light. I had them wired to the wrong tabs on the new LED plug. I did figure it out and it works great.
Neisserj1
Electrical/Lighting/Alarm
Aug 29, 2018 07:26 PM
CGLTD
Mar 17, 2018 12:36 PM
CGLTD
Jan 2, 2018 03:53 PM
barrygreen
Jan 8, 2015 06:57 PM
57red
Dec 4, 2011 07:39 PM
