Electra Glo
Old Jan 4, 2018 | 06:18 AM
jackietan's Avatar
jackietan
Default Electra Glo on Dyna
I bought the 2014 Touring Saddlebag and Sumax Mounting Bracket to install on my Dyna Street Bob. I also bought the Electra Glo. To check which color represent for brake, run and turn?
One side is purple / black & green / purple & white
The other side is blown / black & white / blown & white
My rear and tail light is combine in a housing that has four wire black, green, white & red that I want to combine to the Electra Glo
Old Jan 4, 2018 | 07:57 PM
jackietan's Avatar
jackietan
To check anyone know what is the color represent for brake, run and turn on the Electra Glo?
Old Jan 5, 2018 | 06:52 AM
jackietan's Avatar
jackietan
I have tested it.
Electra Glo
Purple (Three LEDs lighted on the left) / Black & Green (Negative) / Purple & White (Three LEDs lighted on the right)
Existing light
Red (Brake) / White (Positive) / Green (Turn) / Black (Negative)
How can I combine these two light, the Electra Glo and the Existing light?
Old Jan 5, 2018 | 08:55 AM
jackietan's Avatar
jackietan
I have draft a wiring diagram to combine the Existing Light with the Electra Glo. Anyone can help to check will it work or will it cause short circuit?
1. Can I join both the Negative wire from Existing Light with the Electra Glo together?
2. Can I combine the two Electra Glo wires and connect to Existing Light Brake and Running separately?
Existing light
Electra Glo
Old Jan 5, 2018 | 09:38 AM
grbrown's Avatar
grbrown
You can probably check on-line, by going to the H-D website and the Shop tab, to find those lamps. There is usually a link showing installation instructions. May help confirm your research!
Old Jan 5, 2018 | 10:34 AM
jackietan's Avatar
jackietan
The Electra Glo installation instructions for Touring. I'm using it for Dyna, the installation is difference that I'm looking for help.
Old Jan 5, 2018 | 08:34 PM
jackietan's Avatar
jackietan
Originally Posted by blueangel73
I am following this thread, anything I can add to my knowledge of lighting the better.
Hi blueangel, I bought the Electra Glo. It is originally for Touring model, I want to install on my Dyna.
My existing rear light wiring are:
The Electra Glo has six LEDs on each lamp, I tested one of the lamp using a 9v battery
I have draft a wiring diagram, thinking to combine my existing rear light with the Electra Glo. To check will it work or will it cause short circuit?
1. Can I join both the Negative wire from existing rear light with the Electra Glo together?
2. Can I combine the two Electra Glo wires and connect to existing rear light Brake and Running separately?
No Tyme
Motorcycles For Sale
Apr 8, 2019 08:45 PM
jackietan
Sep 21, 2018 12:39 AM
jackietan
May 24, 2018 05:48 AM
jackietan
May 23, 2018 07:50 PM
hockey8787
Jun 29, 2009 09:28 PM
