Fried BCM?
Old May 24, 2018 | 11:38 PM
joshipps's Avatar
joshipps
6th Gear
Default Fried BCM?
Friend was having an issue with the wiring packed away in the frame in front of the tank (throttle side turn signal connection was intermittent)
Pulled the pin apart and decided to try to plug the wires together without the pin- was greeted with a small spark. Headlight and tail lights turn on when the ignition switch is turned. Nothing else works. Is a new BCM in his future?
2013 Street Bob
Old May 24, 2018 | 11:45 PM
joshipps's Avatar
joshipps
6th Gear
Nothing works as in no turn signal lights, brake lights, gauge cluster, etc.. only headlight and tail lights come on.
Old May 25, 2018 | 08:06 AM
joshipps's Avatar
joshipps
6th Gear
Bump. Any help is appreciated. I’m a complete electronics amateur.
Are we potentially looking at a blown fuse? Wouldn’t the BCM mean zero electronics?
I’ll also add that the light on the fuel gauge works as well.
Old May 25, 2018 | 08:18 AM
JustDave13's Avatar
JustDave13
I'd start by checking the fuses. Evidently your friend touched two wires that should not have been touched together.
Old May 25, 2018 | 12:03 PM
nevil's Avatar
nevil
Most likely fuses. The first step to working on any electrical stuff on the bike is to disconnect the battery.
Old Jan 16, 2021 | 08:47 PM
Angel Grageda's Avatar
Angel Grageda
5th Gear
2013 Street Bob
did you ever find a solution to this? I’m having this same problem
Old Jan 17, 2021 | 07:49 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Forget about the original poster, he is long gone.
Tell us the model and year of the bike you are working on.
What exactly is the problem?
Old Jan 17, 2021 | 07:58 PM
Angel Grageda
5th Gear
[QUOTE=Dan89FLSTC;19671020]Forget about the original poster, he is long gone.
What exactly is the problem?[/QUOTE
the bike is a 2018 sportster 883. I switched handle bars and forgot to unplug the battery and now when I turn the bike on only the lights come on. I have no power to odometer no function on handle bars besides kill switch and it only turns on lights.. I changed my fuses and only my battery one was out.. there’s no relays either..
Philhdsg17
Oct 31, 2018 11:26 AM
dvsardina@gmail.com
Jun 26, 2017 08:29 AM
bighosschato
Apr 18, 2014 02:43 PM
HDFatboy98
Nov 30, 2012 11:07 AM
danosrs
Apr 3, 2012 08:43 AM
