Turn signal question
I have a 2008 Harley Rocker C to start with.
I Bought THE EXTENSION turn signal CAPS,
Not so sure on the installation, as you tube has nothing, and only thing I dig up from harley is this link, but doesn't say in instructions for a 2008, yet drop down menu, and switches I have are the same? Thanks Harley!!!
So I sort of I see, looks as if I have to "jimmy" one end of cap up, and than other, to remove... but for my bike, is this on or with switch assembly Off bike?
Theres a spring, etc...
DO I NEED TO TAKE OUT SCREW INTO LOWER HOUSING TO REMOVE THE RIGHT SIDE TURN SIGNAL SWITCH, IF SO, WHATS THE PROCEDURE?
REMOVE THE SWITCH, THAN THE STOCK CAP, WHAT ABOUT SPRING? RE INSTALL SWITCH ITSELF, MINUS LARGER COVER,
AS I CANGT SEE GETTING IT INTO HOLE, AS IT A BIT LONGER,
THAN SNAPPING ON AFTER SWITCH IS SECURE AND BRACKET SCREWED DOWN?
OR CHANGE CAP WITH SWITCH ASSEMBLY AND METAL BRACKET IN HAND?
IF SO, HOW DO YOU "FINESS" LONGER SWITCH CAP INTO HOLE PROPERLY?
SORRY FOR CAPS, older I get I cant see so great, lol...l not yelling./.....thanks in advance..
heres switches I have, chrome, but same crap...
https://www.harley-davidson.com/stor...E&gclsrc=aw.ds
I ride cold weather, etc, and I've had a hard time, at times,
engaging turn signals,
due to heavy gloves/knumb hand,lol, etc....
heres the instructions, again VAUGE, and doesn't mention MY bike, in instruction #1 or 2, thats my dilemma....
https://serviceinfo.harley-davidson....1?locale=en_US
thanks lots in advance, I tried on a old switch,
didnt seem like cap just comes right off
like they make it seem???
thanks, I already installed new brake button, and a new chrome switch,
as I broke old one, trying to install these nice elongated turn signal switch cover caps
looking for advise from anyone you has done, not being rude, just frustrated
this cost me plenty of $$ for one damm cap, other I had installed, this one had to be replaced, other reasons...
While no photos as Zanthamos pointed out we have Type I switch housings and be careful on the right-hand side with the brake light switch. Looks straightforward based on the instructions but note above the use of a hair dryer to warm the plastic before slipping it over the switch posts.
