No Start
Old Jul 11, 2018 | 09:14 PM
bluzman24's Avatar
bluzman24
Default No Start
The last few times when I start my bike there was a random pause before she would fire up. The other night it wouldn't start. No lights either. Someone handed me one of those cell phone sized jump starters and that didn't work and it started smoking. After a minute, I turned on the ignition, got lights and tried push starting, no good. A fellow biker disconnected the Mini Beast air horn and colored LED lights from the battery + ,turned on the ignition ,got lights and she started. I don't know if that helped I was just glad it started. I pulled the battery (next day) ,12.93 volts. Checked for a bad goround ,under the seat ,nothing jumps out. I'm going to check the ignition switch and I'm waiting on a started solenoid rebuild kit (thinking the contacts in the solenoid are going bad). I'm wondering what else to look for. My bike is an 07 Night Train ,with 27K, I've had it 7 years. I am going to check the horn and led wiring. Suggestions please.
Old Jul 11, 2018 | 09:16 PM
bluzman24's Avatar
bluzman24
No blown fuses.
Old Jul 12, 2018 | 08:05 AM
Zanthamos's Avatar
Zanthamos
Do a load test on the battery, your batt may show a good static voltage but the CCA is lower than advertized.
Old Jul 12, 2018 | 04:30 PM
bluzman24's Avatar
bluzman24
Will do sir, my Spidey sense does say my luck is not that good ,where it could be something as simple and easy as the battery. I'll post what turns up.
Old Jul 15, 2018 | 06:16 PM
bluzman24's Avatar
bluzman24
Battery passed, went to the local auto parts store and purchased a starter relay ,just to see if that was a cheap fix. Rode it almost 200 miles yesterday and she fired up the first time every time. I'll install the solenoid rebuild kit in a couple days (another cheap fix attempt).
lewk
Sep 24, 2017 08:37 AM
its_just_me
Jul 19, 2011 07:12 PM
TurdTech
May 21, 2011 09:55 PM
exemexer
Dec 30, 2010 01:50 PM
HarleyMerta
Jul 21, 2010 04:44 PM
