battery
Old Sep 29, 2018 | 09:53 AM
exilebeast666's Avatar
exilebeast666
Stage IV
Default battery
hi, I have a 1999 fxd custom trike with push button start,i am getting a loud single click when trying to start can you help
Old Sep 29, 2018 | 12:10 PM
kel03's Avatar
kel03
Welcome to the forums from Ontario, Canada. Hey, either bad starter, battery, or look at your connections. Where's the sound coming from ?
Old Sep 30, 2018 | 10:44 AM
exilebeast666
Stage IV
Default battery
from the battery box but now there is no click nothing
Old Oct 3, 2018 | 04:02 AM
grbrown's Avatar
grbrown
Cool
Hello old chap, from darn sarf. Does anything electrical work, such as horn, lights, brake lights? My money is on a dead battery, alternatively bad connections on the main battery cables. I suggest you remove the battery from the bike and charge it, using a proper battery charger, not a minder/tender. Check both ends of both battery cables, by disconnecting, cleaning and refitting, preferably with dialectric grease or vaseline, to keep out corrosion. Check your battery for voltage once charged, which should be around 12.5-13 volts with no load. Refit and try again. If the battery doesn't perform well get it load tested at a local car-parts store, which should diagnose if it is OK or toast.
Old Oct 3, 2018 | 02:34 PM
exilebeast666
Stage IV
Default battery
thanks buddy ill try that
GREENOHAWK69
EVO
21
Aug 2, 2018 08:05 PM
Oscarthegreat
Jan 4, 2015 01:37 PM
TexSport2013
Jan 23, 2014 04:47 AM
dart451
Aug 4, 2009 06:13 PM
murph
Dec 12, 2007 10:02 AM
