Custom Harness
Old Oct 16, 2018 | 07:53 AM
BrysZ's Avatar
BrysZ
Originally Posted by BrysZ
I wonder that same thing. I checked voltage at male plug on bike this morning and everything seems right. I'm going to reconnect 2018 harness tonight and check voltage at other end of harness. other then that I'm out of ideas.
Thank you very much for your input
Old Oct 16, 2018 | 07:57 AM
BrysZ's Avatar
BrysZ
Here is how I have the 2018 plug re-pinned now...fyi
POSITION 1 - BLUE/BROWN STRIPE
POSITION 2 - BLUE/RED STRIPE
POSITION 3 - BLUE/VIOLET STRIPE
POSITION 4 - BLACK
POSITION 5 - RED/YELLOW STRIPE
POSITION 6 - BLUE
Thank you very much for any help you can give me!
Old Oct 16, 2018 | 08:09 AM
grbrown's Avatar
grbrown
Red face
POSITION 4 - BLACK
POSITION 6 - BLUE
Looks to me as if you are doing just fine! Following each wire from end to end, on both circuits, should help confirm the correct matching.
Old Oct 16, 2018 | 08:21 AM
BrysZ's Avatar
BrysZ
thank you is 6 volts typical on the dmm? possibly i have the settings wrong
Old Oct 16, 2018 | 09:58 AM
BrysZ's Avatar
BrysZ
Old Oct 16, 2018 | 05:52 PM
BrysZ's Avatar
BrysZ
the red/yellow has power right up to the third light/control module. still no brake light. I don't get it. please help
does a 2018 light not work on a 2012 bike? I have every other light working. running lights, turn signals, just no brake lights. . ugh
BrysZ's Avatar
BrysZ
fender isn't on bike... would that matter?
Old Oct 16, 2018 | 06:01 PM
BrysZ's Avatar
BrysZ
I ran a ground wire from fender to bike. still no luck 😣 please help
Old Oct 17, 2018 | 10:19 PM
d_slat's Avatar
d_slat
I don't think you have enough information to figure out what wires need to go where. You need to follow each wire to the source on each wiring diagram and see what function each wire serves, not just which terminal it hooks to on the module.
Old Oct 22, 2018 | 12:35 AM
Zanthamos's Avatar
Zanthamos
I'm thinking that the fender modules are different and maybe your issue.
HarleyQC
2014-2024 Touring Models
Apr 11, 2014 07:51 AM
BlackPearl#1
Jun 14, 2010 01:54 PM
jdreed520
Feb 14, 2009 01:39 PM
akenaten
Apr 12, 2007 10:11 PM
Gamma742
Jan 28, 2007 11:54 PM
