DYI caused problems, help needed.
Old Jan 13, 2019 | 08:57 PM
DanielJacobsen's Avatar
DanielJacobsen
Stage III
Default DYI caused problems, help needed.
Hello, Thanks for reviewing my DIY related issue. I’ve researched all I could online and came up empty handed. I hope someone has had a similar issue corrected and can offer some help.
bike: 2015 Street Glide Special.
problem:
1)when selecting the “info” button, the air temp no longer works. Just displays “ - -“
2) My cruise control is no longer working at all, can’t even get the icon on dash to turn on.
work completed:
brake pad swap on front brakes only.
entire new exhaust system (headers slipons).
new flash using my FP3
i did not disconnect battery when doing any work. I suspect this when the problems began, but I greatly would appreciate some input please.
Old Jan 13, 2019 | 10:37 PM
DanielJacobsen
Stage III
Fixed, kinda...
reprogramed the FP3 to factory settings and it all came back. I’ll call Vance & Hines to further investigate.
Old Jan 14, 2019 | 08:11 AM
Zanthamos's Avatar
Zanthamos
Well, I was going to say that the flash is what got you as the symptoms are controlled by the ECU, but you beat me to it.
Old Jan 14, 2019 | 08:19 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
You do not need the FP3 with just the exhaust.
The oxygen sensors are not immediate back and forth communication but after a few drives will tune the ECM.
Mundman
Oct 1, 2018 04:01 PM
sixfour
Jan 10, 2018 02:01 PM
TWlST
Apr 20, 2014 08:51 PM
blzbro
Feb 14, 2011 12:51 PM
ultra2006
Apr 22, 2007 12:55 PM
