Tail Light wiring help request
I agree that those blocks aren't the best, but they are readily available. I'm working on sourcing the connector so I can make a properly connected pigtail but they are hard to find.
Anyway, I'm glad I was able to help.
Take another look at that photo above from Cadence Motorsports. Look specifically at that big black connector in the center. THAT is the tag light connector. There are TWO black wires running out of it. Your new bike will have a black cloth sheathing covering them but there are THREE wires going in. Black, Blue, Blue w/red stripe. Ground / Run / Brake. While I've been assuming I need to splice into these three wires (once I finally found the be w/r wire) in fact, all I need is a three pin connector! If you look inside the main harness side of this coupling it already HAS three pins! It is the tag light wire that only has two pins! You don't have to splice any wires. Just add a pin to the plug and a wire to the rear half for brake light function. H-D designed it that way!!! ARGH!
This coupling is DESIGNED specifically for what I'm trying to create! It is merely USED for the modified purpose of the side mount lights in this modified two-pin configuration. If you're up to that sort of thing, you can add a third pin & wire and you're good to go for pennies. If you prefer, a new 3-pin plug is $5.99 in the parts catalog! Part #69201406
A true case of the "K-I-S-S" principle in actual practice!
Glad we were able to help.
