quick disconnect for Zumo
Old Apr 15, 2019 | 10:37 AM
flhrbill's Avatar
flhrbill
Default quick disconnect for Zumo
I have a 2009 Electra Glide Classic, I'm currently using an old Garmin that I hard wired into the extra power lines near the headlight assembly under the fairing. I am using a quick disconnect so I can remove the GPS unit. I have a battery tender type connection that I plug the GPS unit into, I would like to do this same thing with the new Zumo 396 that I am getting. Has anyone done such a thing? Thinking it should work but thought I would get some advise.
Old Apr 15, 2019 | 04:53 PM
LQQK_OUT's Avatar
LQQK_OUT
Have you looking into the Road Tech Zumo 660 & 665 Fairing Mount Kit from HD?
https://www.harley-davidson.com/stor...ring-mount-kit
Old Apr 15, 2019 | 05:20 PM
flhrbill's Avatar
flhrbill
No I ended up going with the Zummo 396 much cheaper than the HD products. And it did get very good reviews
Old Apr 16, 2019 | 10:25 AM
LQQK_OUT's Avatar
LQQK_OUT
I'm not understanding your response. The part I referred to is a mount, not a GPS unit.
Old Apr 16, 2019 | 12:43 PM
flhrbill's Avatar
flhrbill
It’s not the mount that I’m concerned with it’s the actual wiring. I can use the mount I’m currently using which is attached to the handle bar. My main concern was can I cut The power cord and splice it into a battery tender type connection. Then I can disconnect the GPS unit and the mount from the bike. The recommended way of wiring the GPS is directly to the battery. If I do that I can remove the GPS on the mount but the mount because of the wiring would be permanently attached to the bike.
I misunderstood your response.
Old Apr 17, 2019 | 08:53 AM
bustert's Avatar
bustert
really see no issues as long as you correctly match polarity, do not want to reverse charge the gps=smoke!!!
personally having switched power is the way i would go instead of direct to battery.
WRE4U
Screamin Eagle CVO Models
Nov 7, 2017 03:15 PM
nivensid
Oct 29, 2011 10:42 AM
t059736
Dec 20, 2010 03:01 PM
buckwheat
Jun 13, 2009 12:17 AM
rahall
Mar 3, 2009 06:58 PM
