Brake lights blinkers and horn not working
Old May 26, 2019 | 10:11 AM
Mikekennedy's Avatar
Mikekennedy
1st Gear
Default Brake lights blinkers and horn not working
I posted this yesterday but think I put it in wrong spot
Ok on my way to work yesterday I found out my blinkers and horn stoped working get to work and my brake light are out also I have a 2007 heartage softail I tested the fuce and all was good went and replaced them all with new ones the bike has nothing added to it .i checked horn wire it is good tighten ground wire to bat and the other ground and cleaned them looked at plug going to back harness what I did find is dash was a little loos tighten it back up ...this morning started bike before going to work and blinkers was working cool I thought and 2 minutes later nothing again so I am thinking it is a loos wire or burnt one but dont know where to look or can it be the fuse box
Old May 27, 2019 | 04:31 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
The turn signal switches, horn, and brake lights are all powered by the accessory circuit, I suggest you start by replacing the fuse, then look for any obvious issues.
The wire color is orange with a white stripe.
Since everything on that circuit is affected, the problem is going to be between the fuse and the spot where the wire branches out to the different components.
Gbishop303
Apr 12, 2017 06:09 PM
vindyl
Apr 2, 2014 08:17 PM
HBRHMR
Aug 17, 2012 12:37 AM
Dyna7
EVO
18
Jun 12, 2012 05:06 PM
freebyrd
Oct 31, 2008 09:08 PM
