Wiring halo headlight
Old Jul 7, 2019 | 05:59 PM
Wildcatqb15's Avatar
Wildcatqb15
Stage I
Default Wiring halo headlight
Can someone please help me?
I am trying to install my BICYACO HALO Headlight in my 2012 Harley Davidson Fatboy. The light came with a three prong plug and play for the high and low beams, but the halo daytime running lights have an added red wire. And I know I need to wire it to the yellow positive low beam wire. them problem is there are two yellow wires. How do i go about getting this halo light to power up for daytime running lights? Which yellow wire do i splice into? And how do i do it? Just cut one of the yellows right in the middle and cut each side back and cap all three off together? Thank you!!!!!!
Old Jul 10, 2019 | 09:41 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Cap all three together? Seriously, this is not a bathroom light switch, twisting wires together and capping with electrical nuts is AC stuff.
For a nice clean install, without hacking into your wiring harness:
Make up a new wire (Yellow), connect it to the passing lamp switch at the same place there is already a yellow wire, run this new wire into the headlamp bucket and connect it to your new headlight.
Protect the new wire with shrink tube.
HarleyGTP
Aug 13, 2025 10:28 PM
Phil_R
Mar 19, 2018 03:32 PM
blacklabel213
Apr 5, 2014 08:01 PM
VBdiver
Jul 8, 2012 05:03 PM
Sshock11
Mar 22, 2012 05:28 PM
