help.....
Old Feb 1, 2020 | 03:15 PM
tin sandwich's Avatar
tin sandwich
Default help.....
as the title states i need help with a no spark problem. ive gone through all the tests in my manual that i feel comfortable doing. switch is good,coil is good,battery good and fully charged,new plugs and wires ohmed out good. dont know how to check the ignition module .but per the manual i did have 5 volts going to cone. i did not have spark when jumping the two pins in connector.does that mean my module is bad? was running good when i shut it off last time. any ideas or reccomendations on a new module? bike is a 1988 fxrs sp.im stumped.
Old Feb 3, 2020 | 08:07 AM
ghost183's Avatar
ghost183
check your other post in the ECU section...
you have a can sensor behind the timing cover
its probably bad considering all your checks..
btw..
cross posting in multiple sections gets confusing for all of us brother
1988lowrider
EVO
11
Jun 1, 2018 03:31 PM
1988lowrider
May 25, 2018 06:43 PM
jeffneuf17
Jun 29, 2017 02:35 PM
Johns98roadglide
Jun 1, 2013 09:00 AM
jbees
Jul 21, 2011 07:02 AM
