No spark / weak spark.... help!
Old May 25, 2018 | 06:43 PM
1988lowrider's Avatar
1988lowrider
Stage IV
Question No spark / weak spark.... help!
Hello... i have a 1988 fxrp. Last week while riding it just shut off on me. Pushed it to the side of the road, tried starting it again. It eventually started, as soon as i took off it died again. It did this 3x before it wouldnt start anymore. Got it back home, realized the coil was cracked, i replaced battery, coil, wires, and plugs. Wont start. It turns over but no start. Checked kill switch, ignition switch... seem fine. When i checked for spark there was nothing at front plug and very very weak on back one ( im assuming i did the procedure right, takng plug out and put back in wire and lay it on the cylinder) i do have a shop manual and was going to test the ignition module however someone has changed things inside the cone ( dyna s is in there) and the module under right side panel is not hooked up to sensor plate. The white and blue wires on the coil do not come from the module under that right side panel( where the book says they come from) they come from the cone. Any suggestions on how/ what to check next? Im not a mechanic but follow direction pretty well
1988lowrider
EVO
11
Jun 1, 2018 03:31 PM
1988lowrider
May 25, 2018 09:13 PM
Chewyfxd
Dec 11, 2016 06:47 PM
Shackleford
Aug 21, 2014 08:51 PM
zenwarrior
May 19, 2007 11:21 AM
