No spark
Old Dec 11, 2016 | 05:09 PM
Chewyfxd's Avatar
Chewyfxd
Stage I
Angry No spark
Im not getting any spark when starting my 99 dyna fxd. I replaced the spark plugs, the cords that connect the spark plugs to the coil. New coil, and new ignition module. And still no spark. I checked the fuses, and all good. I dont know what do/ check next. Im stumped and need some guidance.
Old Dec 11, 2016 | 06:26 PM
beanoboy's Avatar
beanoboy
Battery o.k. ? How about the ignition switch ? Starter switch ? I presume you are not getting a 'spark' when holding the plug against the 'cylinder head' and hitting the start button, make sure you have the 'cords' firmly connected to the plugs and coil...b.
Old Dec 11, 2016 | 06:47 PM
Ghost_13's Avatar
Ghost_13
Check / test the crank position sensor
eta - also check the bank angle sensor - may be bad and shutting off the spark
Ghost
crestwood
Electrical/Lighting/Alarm
14
May 27, 2024 02:48 PM
prezident62
Jun 24, 2016 09:56 PM
48 Special
Apr 13, 2016 07:01 AM
tugboatlife
May 19, 2014 06:31 PM
Rags26
Apr 27, 2008 12:02 AM
