Battery Charger For Storage
Old Nov 1, 2005 | 10:00 AM
HDF Tech's Avatar
HDF Tech
Default Battery Charger For Storage
Any battery in storage for winter or extended periods of time will give longer service life if a battery tender is used to maintain a full charge. This is the type that works well with a float mode with an output of .750 amps, also various accessories for the unit ... HERE
Or another source with extra cables ... HERE ..Or . HERE
Here's a selection guide with charger info... HERE
Battery Tender ( The larger one 1.25 amps output )
A Battery Tender is similar to a trickle charger but will not overcharge your battery. Batteries in storage will lose a good portion of their charge in just 14 days! Standard trickle chargers can overcharge and permanently damage the battery. The Battery Tender puts an end to this worry. Connect the alligator clips to your battery terminals, plug it into a wall outlet, and that's it! It will maintain a 100% charge constantly: enough to ensure starting power, but not enough to boil away electrolyte and damage the plates. It even senses incorrect connections and will not charge if the polarity has been reversed.
Though I ride enough to keep my battery charged,I keep the Battery Tender attached to my bike when not riding for periods longer than a few days. My past bikes have never left me stranded with a dead battery. You can even make it easier to connect by wiring a cigarette lighter socket to your battery and mounting it somewhere on the bike, and a male connector to the charger's clips. This setup even doubles as a lighter if you have the correct one.This inexpensive modification now allows you to charge your bike without pulling the seat off each time.
What I use is an inexpensive two prong chrome connector, available in any boating supply store, mounted to the bike for the purpose of a connection, if it doesn't allready come with the pigtail when you buy the charger.
[IMG]local://upfiles/2318/3F4B675C8B6A4DF4926711B71E282E85.jpg[/IMG]
Also see> HERE < for more info on batteries.
patriotmc
13
Nov 5, 2017 07:45 PM
JONNIEROCK
Oct 22, 2017 03:07 PM
bama6977
Jan 4, 2012 10:29 PM
snuffer
Dec 3, 2007 10:26 AM
falsealarm
Nov 21, 2007 03:22 AM
