Have you used a Power Vision or anything on it? I know PV can calibrate it but it will void your powertrain warranty. Did you change rear tire size (taller/shorter or larger/smaller rim)? If none of the above then talk to the dealership, there may be an issue that falls under warranty.
Stock bike. Rear tire is getting worn, if speed is taken from the rear wheel ABS ring.
Otherwise I couldn't believe how far off it was when I clocked it on a highway odometer check section.
After 3 miles it was reading over 1/10th mile high.
Speed is taken from the speed sensor in the top plate of the transmission not rear wheel ABS. Shorter rear wheel will impact odometer and speed readings.
