99 fxwg
Old May 11, 2020 | 11:12 AM
LDB187's Avatar
LDB187
Default 99 fxwg
Put a new battery in but it's not holding a charge. Also when I get up to around 70+ mph the engine light comes on until I slow down. Could this be the stator or alternator or some other electrical issue? TIA
Old May 13, 2020 | 09:26 PM
Zanthamos's Avatar
Zanthamos
Do a charging system check, if you start it and run it at 2000 rpm the voltage output to the battery should be between 14.5V and 15.5V. If not then you have a charging system issue, if it is good then get the battery tested, even new batteries can fail.
lospuerco
May 7, 2016 08:46 AM
fettnersa
Jun 16, 2015 01:21 AM
Pcrebuilder
Dec 15, 2014 09:25 AM
fettnersa
Sep 1, 2012 05:10 PM
tekeum
Sep 23, 2009 04:42 AM
