check engine light with battery light
Old Sep 20, 2009 | 09:59 PM
tekeum's Avatar
tekeum
Default check engine light with battery light
my check engine light & battery light is on my volt meter is showing about 12. Is it a charging problem, bad battery what am I looking for? It all started when I had the lower dash off with ignition switch out when I took it out the clock was on. did I drain the battery it was on for about 6 hours. I went on a 2 hour ride and it came after I stopped at the store. I am going to put it on the charger for the night and see if that helps. Any other ideas let me know
Old Sep 21, 2009 | 04:58 AM
Bulish's Avatar
Bulish
1st Gear
Same problem I had on my 06 EGS. It was the voltage regulator.
Old Sep 21, 2009 | 05:13 AM
JayStronghawk's Avatar
JayStronghawk
Check Voltage when Bike is off then crank it up and check when running .. Engine Off is 12.7 is 100% Charged... 12 Volts Off is only 25% Charged .. When Running and Charging properly should have 13+ Volts at the Battery .. Can also try a load tester but this is only recommend to do with a Fully Charged Battery if can't get at least 12.6 Volts after Charging I would replace the Battery .. Although also check if your charging circuit is faulty and what caused the Battery Failure..
Old Sep 21, 2009 | 06:24 AM
hojones's Avatar
hojones
Have you checked the plugs on the bottom of the regulator? Sometimes the retainer will lossen and the connecter will fall loose.
Old Sep 21, 2009 | 12:15 PM
tekeum's Avatar
tekeum
Ok update charged the battery last night it took the charge fine. So I took it up to the local battery shop to see if it was charging properly and it wasn't at idol it was only 12.2 with some RPMs 12.8 It is needs to be around 13.6 wright what do I need to replace if it is not charging? I feel stupid I can build custom jeeps, cars, & trucks but I feel lost with this bike. I do all my own service. I don't want to take it to the dealer. help!
Old Sep 21, 2009 | 12:50 PM
JayStronghawk
If do your own Wrenching try the Voltage Regulator First and Pray that does it .. If not will have to be getting into deeper stuff .. But start simple if not the Regulator would be a good idea to replace it anyway if have to get into the Stator..
Old Sep 23, 2009 | 12:08 AM
tekeum's Avatar
tekeum
Talking
up date I bought the bike used in my so I figuered the warinty was up. so I went into my dealer to buy the voltage regulator $180+ the sales guy asked if i was still under warinty I said I dont think so. I gave him my vin number he told me I have a wainty until Feb 2010 so there going to fix it
Old Sep 23, 2009 | 01:01 AM
JayStronghawk
Good news for sure... Just follow through and ensure that all is well .. Good luck
Old Sep 23, 2009 | 04:42 AM
hoytheld's Avatar
hoytheld
just went through the exact same problem on my '06 RK....it was the voltage regulator as well. But....my warranty expired in August...a month to soon! $246 out the door replaced by dealer. I am in the same boat as you...I am a fabricator...not a bike mechanic....I will know next time...you can get voltage regs on ebay for $120 and less.
lospuerco
May 7, 2016 08:46 AM
adam31093
Sep 4, 2013 07:29 PM
darrinfish
Aug 22, 2010 07:27 AM
dogit56@aol.com
Nov 27, 2009 12:13 AM
SpiderPig
Jul 15, 2008 11:24 AM
