YES or NO question for ya?
Old May 16, 2020 | 09:42 PM
Superdog3:16's Avatar
Superdog3:16
Default YES or NO question for ya?
I know a little, but not enough. I just put an aftermarket header on my 2014 103 RoadKing. What a friggin pain I'm my ***. Shoulda went with v&h like I planeed.
one of the bungs for the O2 sensors is waaay outta place from the stocker and the sensor cable is too short to run the way it was to the connector. Here's my question. CAN I SIMPLY SPLICE IN A SIMILAR GAUGE WIRE TO LENGTHEN IT OR DOES IT HAFTA BE A CERTAIN TYPE OF WIRE? I'm thinking the sensor is a type of analog input, not digital. Anyone tell me yay or nay for sure?
Old May 16, 2020 | 11:32 PM
Zanthamos's Avatar
Zanthamos
They make the extension for plug n play applications see: https://www.harley-davidson.com/stor...ness-extension for an example. I was one from V&H one from Namz and a few others besides the HD one.
Old May 17, 2020 | 12:04 AM
Superdog3:16
I will definitely check it out. Off hand, I'm concerned that the connection plugs between cable and extension will be unhidden/unsightly in the open for to being too short to make it behind the side cover. Thank you. Still like to hear if these can be spliced. I suppose maybe get an extension, then remove the connectors and solder it? Idk. Is that what you meant?
Old May 17, 2020 | 12:07 AM
Superdog3:16
Thats to hook up a tuner to the bike through the sensor plug. Looks to me. That ain't gonna work.
Zanthamos's Avatar
Zanthamos
You cou,d do that or just look and see what you have to work with. Generally I'm against modifying main harness so I'd go on the O2 sensor side for the splice.
Old May 17, 2020 | 12:24 AM
Zanthamos's Avatar
Zanthamos
Originally Posted by Superdog3:16
Thats to hook up a tuner to the bike through the sensor plug. Looks to meet. That ain't gonna work.
While yes it is for the street tuner pro auto tuner, it is only the O2 sensor signals and just a straight through connection with the same connector.
Old May 17, 2020 | 01:40 AM
Superdog3:16
Oh absolutely, for sure!
Old May 17, 2020 | 07:33 AM
MyFavRk's Avatar
MyFavRk
I ended up splicing ( soldering ) wire into one of my 02 sensors ( can't remember which one ) . As long as you use the same gauge wire you'll be good . I have an FP3 and my readings out of both are the same , so length of wire didn't affect it at all . I added about 6" of wire just below the connector and used an " in line " solder to join them .
Old May 17, 2020 | 08:15 AM
Superdog3:16
Thanx MyFavRK. You bail me out all the time,
Old May 17, 2020 | 08:38 AM
MyFavRk's Avatar
MyFavRk
Always happy to help when I can !
