Starting problem
Old Sep 22, 2020 | 08:28 PM
Kevin Collins's Avatar
Kevin Collins
Default Starting problem
I have a 2009 Rocker. The other day I rode about 180 miles stoped to fill up and went home. After parking outside the shed I went to put it up, put the key in the switch, and turned on the ignition and it started and the starter motor stayed engaged. Shut it down turned everything off and did it again with the same problem??? I’m hoping it’s something simple like a relay. I’m going to start taking it apart tomorrow night so any help would be appreciated !!!!
Tks
Old Sep 24, 2020 | 06:43 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
If you turn off the engine run/stop switch (kill switch) on the handlebar, does the starter continue to run?
Old Sep 25, 2020 | 05:08 PM
Kevin Collins
No but it starts when I turn on the ignition and the starter continues to run
Old Sep 25, 2020 | 06:34 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Set kill switch to "off " position.
Turn ignition switch on.
Does starter run without pressing button? If yes, stop.
If no, continue:
With ignition switch still in "on" position:
Set kill switch to "on" position.
Old Sep 26, 2020 | 01:50 PM
Zanthamos's Avatar
Zanthamos
Sounds like starter switch or wiring short to starter switch.
al704
Sep 1, 2019 09:33 AM
rusty289
Sep 1, 2015 06:28 AM
LQQK_OUT
Jun 2, 2015 10:31 AM
stbob07
Sep 11, 2012 09:16 PM
Booey424
Jun 1, 2011 01:31 PM
