Deutsch connector
Old Nov 15, 2020 | 01:52 PM
coop creek's Avatar
coop creek
One thing I have discovered with the Deutsch terminals (contacts). The crimp on the wire (conductor) is "B" shaped, but the crimp on the insulation needs to be a "D" shape. The arms for the insulation crimp are offset from one another, and they are meant to pass by each other and encircle the wire in the shape of a D or O. So if you are planning to use an inexpensive crimper and crimp in two steps, you will need a crimper that has both M shaped and D shaped dies. I am still experimenting and have ordered a Sargent 1026CT crimper that I am going to try out once it get's here. I am using smaller contacts than you, size 20 for the smaller DTM connectors.
Old Nov 15, 2020 | 01:55 PM
coop creek's Avatar
coop creek
another option would be to use solid contacts and a tool aid 18880 crimper for size16 contacts, I am going to try the 18890 crimper as well.
Old Nov 15, 2020 | 03:14 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
The crimper I posted a link to will properly crimp the contact onto the wire and the insulation in one step.
Old Nov 19, 2020 | 09:45 AM
eighteight's Avatar
eighteight
Originally Posted by kel03
I think there's a "Y" connector you can use also, allows you to have a spare connection for later.
Switched circuit adapter harness
p/n 70264-94A
EGS
Electrical/Lighting/Alarm
Apr 19, 2020 11:29 AM
JTBarrett
Aug 9, 2017 10:58 AM
jclax01
2014-2024 Touring Models
Apr 25, 2016 09:30 AM
LQQK_OUT
Apr 9, 2012 10:04 AM
Motown_HOG
Nov 5, 2005 10:32 PM
