intermittent blinkers
Old Nov 22, 2020 | 01:51 AM
aussiemick's Avatar
aussiemick
Default intermittent blinkers
Hi everyone I have a 96 heritage.the right hand side blinker stops when the revs are above idle,have tried a new module and it did the same.blinker works fine when stopped and engine running but stops a a fast rev like if you're downshifting etc.has anyone have any ideas where to start looking.thanks alot
Old Nov 22, 2020 | 01:49 PM
larsfum's Avatar
larsfum
Does it return to normal when the RPM's go back down, or once it is out you have to stop the bike and restart it? You already ruled out the Module, unless that one is bad as well. Try swapping the bulbs, left to right, and see if it happens on the left side then. After that, break out the DVOM, and chase wires doing a wiggle test. Maybe there is an open somewhere that only happens when the bike vibrates under rev.
Old Nov 22, 2020 | 04:32 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
When the problem occurs, do both front and rear turn signal lamps and the indicator in the dash stay illuminated?
Old Nov 22, 2020 | 10:08 PM
aussiemick's Avatar
aussiemick
no they go out .thanks
Old Nov 22, 2020 | 10:10 PM
aussiemick's Avatar
aussiemick
Ok ill give it a try thanks
Old Nov 23, 2020 | 06:30 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Do the signals come back on and blink normally when the revs come back down?
Old Nov 24, 2020 | 12:22 AM
aussiemick's Avatar
aussiemick
Na you have to push the switch again..i have a auto electrician mate who's coming over sat ..so we,ll start at the front and go to the back till we find the gremlin...thanks again.ill let you know what happens
Old Nov 26, 2020 | 10:53 AM
Andyintheshed's Avatar
Andyintheshed
Default Wow! That’s exactly what’s started happening to my ‘95 Sportster!
Well,
almost... Sorry, Aussiemick, if you thought this might be ‘the answer’...
My Sportster indicators are staying on at higher revs. But the trouble seems to have started on the RH side, just like yours (coincidence?) with engine off it flickers instead of blinking. At anything above tickover (riding) both sides will light up but not flash.
The hazard light option works ok! 😖
So, I am also awaiting ‘the answer’!
Cheers
Andy
’95 Sportster
Hampshire
UK
Old Nov 27, 2020 | 12:19 AM
aussiemick's Avatar
aussiemick
Hi Andy hopefully will have a answer in the morn
Old Nov 28, 2020 | 04:36 AM
aussiemick's Avatar
aussiemick
Hi guys we seemed to have fixed it.how,I don't know..we moved a earth connection to another place,pushed a dodgy wire into the connection box,that's what I call it I don't know the technical term for it and it worked..put the seat back on and back to the **** again..seat back off,pulled the connection boxes apart sprayed some contact cleaner in took the fuses out cleaned with son wet,dry and contact cleaner and away it went.went on a 200 km ride and it didn't miss a beat.so l don't know what we did.i thank you for your input and hope you all have a good Christmas and. Keep away from the. Plague.thanks again
