intermittent blinkers
Old Nov 28, 2020 | 05:11 AM
Jackie Paper's Avatar
Jackie Paper
Too cool. Those connections are important. Like a boat anchor or a sink drain, if it's not connected, they don't work well. I have seen it do what yours was doing and it was the light bulb.
Older Harleys' use to have a little disk in the lamp housing that kept the bulb contacts separate. The disk would crack and bike vibration would make and brake cross connections.
Old Dec 11, 2020 | 01:47 PM
Andyintheshed's Avatar
Andyintheshed
Congrats
on getting your indicators sorted, Aussiemick
Mine, on the other hand, are still playing up.
After having cleaned & checked the front ones, plus the connector blocks in the headlamp, all seemed ok.
A test run, however, came up with
LH Will blink at lower speeds, but stay ‘on’ at higher revs.
RH Will try & ‘blink’ but not properly go ‘on’ ‘off’ if you get my drift.
Back to the bat-cave. All tests as per the manual (checking for signals from the switches, bridging pins, a good earth via the black lead). Were ok. I checked for voltage at the accessories fuse - ok, same as the battery, so the ignition switch is good. I checked the voltage of the L&R switch signals. Both about 1 volt down from the battery voltage, but then, the lights were on at the time as well, so I figured that was ok.
The hazards work ok.
It’s the module, isn’t it?
Andy
’95 883 Sportster
Hampshire
UK
Old Dec 12, 2020 | 06:08 AM
aussiemick's Avatar
aussiemick
Jeez that's weird.see if you can try before you buy the module cause mine was gonna cost 250 bucks.good luck🤞
Old Dec 13, 2020 | 10:21 AM
Andyintheshed
Default It’s the module....
After having checked pretty much everything, I got to puzzling why can’t you test the turn module?
I don’t want to spend a fortune on a new module unless I have some proof.
Suddenly 💡 Inspiration!!!
I could test the module!
Here was my cunning plan:- the problem was on the LH side. If I swapped over the leads into the module (the pulse signal leads and the switch leads) I would make the Rh switch operate the left turn signals and the Lh switch do the right hand side!
So?
So...... If the symptoms stayed with the Rh side (so I figured) it would prove that there was a wiring glitch.
But if the fault moved across to the Lh side, it would prove there’s an internal fault in the Rh pulse signal circuitry.
The fault moved....
Bugger.
Andy
’95 Sportster 883
Hampshire
UK
Old Dec 15, 2020 | 10:11 PM
aussiemick's Avatar
aussiemick
Damn that's gotta **** ya
Old Jan 18, 2021 | 11:46 AM
Andyintheshed
Default And the next thing that happened.....
So,
having identified the dodgy indicator module by subtle process of deductivation, I celebrated by treating myself to a flashy multimeter.
Armed with said device, I thought I’d do a quick charging voltage check across the battery terminals (I had been topping up the battery rather frequently, before I bought a new one a little while ago).
Result:- fast idle voltage = 17.9.....
Looks like I need a new regulator. Bugger #2
At least I’ve had plenty of spending cash, thanks to this wretched virus and it’s side-effects....💷
Andy
’95 XLH Sportster
​​​​​​’12 FLS Slim
Hampshire
England
PS Take care of yourselves & each-other over there, especially for the next few days 🇺🇸
Old Jan 19, 2021 | 09:24 PM
Max Headflow's Avatar
Max Headflow
"deductivation"
New word. I like it.
Jagtint
Engine Mechanical Topics
28
Feb 23, 2018 12:02 PM
theterribleone_vdc
Aug 19, 2016 07:39 AM
Raul Duke
Apr 13, 2016 03:29 PM
jhend
Aug 28, 2014 10:06 AM
mac8985
Jul 26, 2010 03:16 PM
