complete DIY wiring.
I decided to do the wiring myself, I'm an electronics technologist so this is not a big deal.
I may have a few questions when I'm further in my build but I will start with two and see where this thread evolves.
I have the generator (# 8 on the drawing) and the voltage regulator (#9 on the drawing). Which pin from the voltage regulator go to which pin of the generator.
Or more specifically on the schematics the pins are identified as B+, D+ and Df and on the connector they are 1,2 and 3. See top right corner of the schematic.
If anyone knows, something like this would help B+=1, D+=2 and Df=3.
I may have figured it out, if the colors on the connector coming out of the voltage regulator match the drawing, I should be good.
I'll check when I get home.
I'm assuming here that the back plate of the voltage regulator is ground.
See attached pictures.
Also #15 on the schematic. which side of the ignition coil goes to 16. There are no markings on the Ignition Coil so I can't tell.
One side has a bigger screw than the other, that's it.
This is a project I'm working on with my 80+yo dad so I don't want to hear "you should buy a complete bike".
O.E. # 70001-76
V-Twin # 32-7614
J&P Cycle # 300-075
on the coil, power into the left side when mounted and right to the points.
hd used two diff regulators and as you guessed it, has diff markings. now is the time to go electronic. i would have to pull some documentation to make for sure but do not have the time now, have to go to the farm.
it is a great project and i hope the best, these machines are an open canvas and with care can lasts decades, mine has nearly 200k miles.
The voltage regulator I have is (I suspect) from a newer model so it is electronic.
Do you mean the hole at the front and the other hole over the rear valve cover?
Yes, the white chair is for my Dad :-)
