Alarm system
Old Jan 23, 2021 | 05:51 PM
Crossbones357's Avatar
Crossbones357
2nd Gear
Default Alarm system
I purchased a 2010 Harley crossbones at an auction.
does not have the fob or a security code. So I bought a new security system but, everything I read tells me I have to disarm the old system which I cannot do without the code or the fob. Can you anyone help me on installing this new system and removing the old system?
Tim
Old Jan 23, 2021 | 06:07 PM
CoolBreeze3646's Avatar
CoolBreeze3646
As this is your first post - Welcome to the Forum.
Probably should contact a dealer as they will have to set up the security system & marry the fobs with the ECM/BCM using the digital tech.
Old Jan 23, 2021 | 06:22 PM
Crossbones357
2nd Gear
I’m gonna hold out and see if one person on here knows the magic and can give me a hand.
thank you for responding
Old Jan 23, 2021 | 07:41 PM
NODYNA's Avatar
NODYNA
If the new security system included a new BCM then all you need to do is get the bike to a dealer to install, if you can't install, and they'll program it. No different than removing a "stock" BCM to upgrade to an alarm BCM. My last touring bike I upgraded to security rode to dealer installed new BCMin parking lot and wheeled it into service waited 30 minutes rode home.
Old Jan 24, 2021 | 12:06 AM
Crossbones357
2nd Gear
I do not have a Harley dealer anywhere near me, I will figure this out
Old Jan 24, 2021 | 11:55 AM
NODYNA's Avatar
NODYNA
Did you try the factory default code 11111?
Old Jan 24, 2021 | 12:24 PM
Crossbones357
2nd Gear
The only default code I’m aware of is; 31313
can you tell me where you found this code ?
Old Jan 25, 2021 | 08:43 AM
Vernal's Avatar
Vernal
There is a procedure called Password Learn that you have to go through when replacing the TSSM. From what I read the fobs need to be paired with the TSSM before the process and it appears you need the Digital Technician or aftermarket device to do that.
Is the replacement you bought brand new or are the fobs and TSSM paired?
Old Jan 25, 2021 | 05:37 PM
Crossbones357
2nd Gear
I purchased a brand new system. Nothing is paired. I wondering if I plug the new one in, will it recognize the other systems, and will I see the default code.
Old Jan 25, 2021 | 05:50 PM
Iceman24's Avatar
Iceman24
You could try, but you're probably digging a deeper hole w/ security system function. Understand there's no dealer in immediate area, but have you called the closest one f/ guidance-recommendations? If not, I'd start there.
