LED Headlight Issue...NEED HELP! ('95 Road King)
Old May 3, 2021 | 07:36 PM
Idiocracy's Avatar
Idiocracy
Good news. I'll see what mine does tomorrow with proper voltage. Thanks.
Old May 4, 2021 | 12:48 AM
Zanthamos's Avatar
Zanthamos
Usually the high beams on these LED lights won't come on unless you have the 12VDC so as to not run the battery flat, quick and easy test is to start the bike. If your charging system is working properly then you should have a minimum of 12.xx VDC at idle so the high beam should work.
DaHobs
Nov 3, 2021 08:29 AM
Circa58
Aug 27, 2018 12:21 PM
wombat457
EVO
126
Apr 19, 2015 08:08 PM
joflewbyu2
Dec 14, 2013 12:19 PM
dclapp
Jun 11, 2006 07:26 PM
