Electrical issues
Old Sep 8, 2021 | 03:27 PM
myharley 726's Avatar
myharley 726
Default Electrical issues
My bad , I disconnected the right hand switch wiring and turned the key on the lights in back went off I plugged all of them back in and just unplugged one wire at a time the lights went out when I disconnected the orange or gray don't remember which
Old Sep 9, 2021 | 08:34 AM
Vernal's Avatar
Vernal
If it was the gray then you may have found your problem. The gray wire is from the Ignition fuse and puts power on the on/off switch. Turn the switch on and the W/BK wire energizes the system relay, puts power to the start relay and tells the ecm switched power is on. The gray wire also gives Tssm a signal.
disconnect right hand controls and see if gray is common to anything other than W/BK.
Old Sep 9, 2021 | 08:41 AM
Zanthamos's Avatar
Zanthamos
Look at the front brake switch, you said that you just put some apes on, did you wedge the brake lever when installing the brake master cylinder? The common issue with brake lights staying on especially after a bar job is that the little nipple at the end of the brake switch gets caught on the brake lever and breaks off leaving just the end of the rubber boot making the switch too short to engage the lever properly. This is mitigated by using a piece of zip tie refuse or heavy card stock to wedge the lever slightly open upon installation of the master cylinder, do not remove the wedge u til the master cylinder and the switch housing are fully installed and torqued.
Old Sep 9, 2021 | 04:26 PM
myharley 726
That diagram did help some thanks on a few other little items that needed fixed
Thanks for the help, I checked the front switch the lever wasn't even touching the switch so I repositioned the lever now the brake light is off and working properly the only thing left is the CDI BOX my guess is the tail light is going through that box as soon as I get the box I'll get it put in and hopefully the tail light Will work. Thanks guys for all your help greatly appreciated.
Old Sep 9, 2021 | 04:44 PM
Zanthamos's Avatar
Zanthamos
What is this CDI box that you are talking about?
Old Sep 9, 2021 | 04:45 PM
Zanthamos's Avatar
Zanthamos
Old Sep 11, 2021 | 11:38 AM
myharley 726
Default Electrical issuesa
Actually it's the ignition module, I purchased a repair manual it got here yesterday I was looking at the harness for my bike this manual is worth it's weight in gold. I can't do much until I get the new ignition module it should be here in a day or two. This forum is Worth it's weight in gold as well there are a lot of helpful people on here and I thank everyone for all the help you have also given me it means a lot to me and is greatly appreciated.
Old Sep 12, 2021 | 06:18 AM
Zanthamos's Avatar
Zanthamos
The wiring diagrams I supplied are from HD for your bike. Did you get the HD FSM or some other repair manual?
ruckus4offroad
Dec 21, 2013 11:11 PM
Ted Tyler
Aug 14, 2012 10:54 PM
Rhino //
Jul 3, 2011 06:31 PM
Weatheredge
May 30, 2011 07:29 AM
8upFLHRI
May 18, 2008 07:15 AM
