So I've been digging for hours and can't find anything. Just got my new street glide on friday and it had a dead battery (not completely but not enough to crank it over) in the first 100 miles I've gotten a small red light on dash accompanied with no running lights and it happened in bumpy areas. Checked codes and have a b2168 running lights output shorted low. It has dealer installed custom dynamic led turn signals and i installed taller bars. I noticed the code before doing the bars (CEL after dead battery made me dig into codes) but i checked all the wiring behind fairing and between bulbs and socket in the turn signals. Looking to see if anyone here has any thoughts or ran into this issue before i talk to a dealer tuesday when they open.
Welcome to the world of electrical gremlins after swapping bars...first rule = check your connections as something's either pinched/grounding/cracked/split. Re-trace your steps as something's amiss w/ the continuity.
I've circled back and checked every wire i touched and i noticed code was there before bar swap
