Load equalizer
Old Mar 18, 2022 | 10:35 PM
Ed Ramberger's Avatar
Ed Ramberger
Originally Posted by 07UltraGuy
A “load equalizer” is nothing more than a resistor pack. The only difference is that it moves the heat to a place outside the fixture housing, away from the LED array.
This is beneficial from a longevity standpoint, as it maintains lower operating temps for the LEDs.
Cooler LED’s = longer lasting LED’s.
I have a plug n play load resistor in my circuit as well; located under the seat.
Given the size of the heat sink on the Custom Dynamics lights that I have, I suspect they will outlast the rest of the bike.
LED friendly flasher technology eliminates the antiquated resistive load. The Smart Triple play is that technology. Believe me that the resistive load equalizers get very hot when they have been on a while.
In addition it allows you to adjust the brightness of whatever LEDs you bought to match whatever brake light you have.
On top of that it has features such as multi-flash on initial braking.
It also turns your running lights into brake lights if you desire. The combination of no resistive load and features it offers makes it a no brainer if you want the lighting to match and have as much lighting (safety) as possible. These are the reasons why I said the OP would thank me later going that route.
Old Mar 18, 2022 | 10:44 PM
fastsoup's Avatar
fastsoup
Whoa! That's a lot of features...how come you didn't mention those 😉.
So this is the Gen2 we are taking about? It will allow for "strobe blink" of my brake lights when I first apply them? And will it allow the led tail lights in my TP to light up as brake lights?
Old Mar 18, 2022 | 10:46 PM
Ed Ramberger
Yes
https://www.customdynamics.com/load-...arley-davidson
Old Mar 18, 2022 | 10:49 PM
fastsoup's Avatar
fastsoup
GREEEAT! it's out of stock 😆
Old Mar 18, 2022 | 10:55 PM
Ed Ramberger
J&P cycles has them in stock. Just look up the correct one for your bike from the CD website and hop over to J&P. I ordered all my CD stuff from them and had it in a couple days.
You can also look at the instruction sheet on the CD site. They tell you it can work with normal bulbs and how much is too much load.
Old Mar 18, 2022 | 11:48 PM
fastsoup's Avatar
fastsoup
Thanks Ed!
Old Mar 19, 2022 | 12:08 AM
Ed Ramberger
Thanks Ed!
Anytime!
Old Mar 20, 2022 | 08:34 AM
eighteight's Avatar
eighteight
I got a nice set of 1156 LED'S with built in resistor...no hyper flash atm...and very little heat after 1 min. Not sure I really car about the extra 30 secs of extra load when my LED'S are blinking...care more about being seen!
Product name or link please.
Thank you
Old Mar 20, 2022 | 11:33 AM
fastsoup's Avatar
fastsoup
Thank you
Teguangmei BAU15S PY21W 1156 7507 LED Bulbs Canbus Error Free Amber Yellow Turn Signal Light No Hyper Flash 3030 45SMD 3700LM Blinker Bulb for Car Front/Rear Turn Signal Lights Replacement(2PCS)
Amazon Amazon
Old Mar 24, 2022 | 08:30 AM
slw210's Avatar
slw210
Custom Dynamics is the only way to go. Well worth the money and I'm a cheap bastage.
Now, if they would just make stuff for my 2003 Suburban.....
bikernutgoofy
14
Apr 9, 2015 09:05 AM
bigjosh42
May 13, 2014 07:28 AM
Streetrunner
Jan 20, 2012 09:16 PM
Lawdawg
Jan 7, 2009 08:49 AM
zukeeper
Feb 21, 2007 03:11 AM
