need help identifying mysterious wires???
Old May 27, 2022 | 03:11 AM
miky2001's Avatar
miky2001
Default need help identifying mysterious wires???
the bike is a 2005 softail springer classic with efi.
there are 2 extra wires wrapped up under the headlight, one is pink, the other is grey. the ends have right angle connectors on them that are not connected to anything.
i traced them and they go under the gas tank.
the grey one is goes under a motor mount bolt, so its a ground wire, but for what?
the pink wire ends in another right angle connector, but its not connected to anything.
so these 2 wires dont do anything, but i want to know what they are for before i get rid of them.
thanks for any clue as to what they may be.
Old May 27, 2022 | 06:11 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
OEM ground wires go to the ground points on the frame, a gray wire going to an engine mount bolt suggest someone added an electrical component.
I don`t see any pink wires on the wiring diagram.
I suggest you pull the tank and see where the pink wire goes...
dieselbeef
Jul 9, 2021 07:47 AM
19mandy.clarkson77@gmail.com
Sep 17, 2016 04:14 PM
matt76cmich
Audio Systems
11
Aug 30, 2015 06:19 PM
Ironhead666
Electrical/Lighting/Alarm
Jun 15, 2014 07:22 AM
Doc Danielz
Apr 9, 2011 09:47 PM
